Buckeyeshane
Thread starter- Joined
- Apr 27, 2009
- 6
I have a problem with a 9.9hp Mercury 2 stroke outboard motor. I am not sure of the year of the motor (the serial # on the motor is 08101084). The problem is the fuel line going directly into the motor (after the primer bulb) goes into what looks like a fuel filter (not sure) and it fills up with fuel and overflows out of it like it's not sealed. When the motor is idling it will drain this fuel filter or whatever it is then start to starve for fuel until i pump the primer bulb to fill it back up. What is this part?? Being that when I fill it with the primer bulb and the fuel flows out the top of it is it my problem?? When we are out on the lake running WOT it runs fine until this runs out of fuel in this part then I just pump the primer a few times and were good for another few minutes. Thanks for any responses
