1982 Evinrude 35hp Shift Rod Screw
jkotlik
Found this site just recently and have found it very useful. Thank you for all of your help so far.
I am changing out the water pump assembly on this motor i picked up and for the life of me i can not figure out how to disconnect the shift rod. Please could anybody help me. I have looked under the carb like some of the other posts have talked about but i can just not figure it out.
early thanks
-James
Re: 1982 Evinrude 35hp Shift Rod Screw
that one is really hidden. below the AV plate and above the prop, is an inlet screen, remove the screen, you will see a compression fitting, release the fitting, slide the top nut up, and remove the packing, now the lower will slide down. see item 29
Doolin
Thank you soooo much. I spent most of the day trying to figure this one out. It was the most frustrating thing I've come across on this boat so far.
Started it up today to make sure it was going to start easy and run good for a trip planned for Wednesday. No pee.
I've had the boat for a couple years and never checked the impeller so, I figured it was time anyway. The shift coupler behind the water intake was a challenge... the manual helped with that one.
But once disconnected... I couldn't get the rod past the water pump housing. The nut wouldn't come off the end of the shift rod. I finally unbolted the impeller housing to get the lower unit off (it was hanging on that nut). Once off... I could see all the way to the top of the shift rod and could see the shaft it was on... held in place by a cotter pin.
I caught a thread that mentioned an access plate (I now think that was in refference to the lower nut) but took off the starboard motor mount thinking it was hiding an access hole. No luck... and had to make a special tool to get the darned thing off... Doah!
I also totally disassembled the upper shifting mechanism... looking for a way to get it to 'let go' (no luck and totally unnecessary).
You of course... had the answer. The manual didn't do a good job of describing how to get that nut off, and there was no picture. The exploded diagram was too small to see it either.
In case anyone else gets stuck on this one, I took a small socket and lined it up on the bottom of the 'top' threaded nut... which is on the bottom of the shift rod. I tapped the socket up the rod about 1/2 inch exposing a tapered split washer. Carefully, with a flat screw driver, I pried it out of it's groove. Then pulled and tapped the nut down off the end of the shaft... WOOHOOO!!!
I love this site :D
Thanks again,
Ben
