Volvo Penta(AD41P-A) DP sterndrive lower unit gear oil
rayan
Hello to all,
:(i have a problem....i have a boat with two Volvo AD41 and DP sterndrives. when i was changing the lower unit oil, made a big mistake and put the engine oil (15w-40), insted the gear lube (75w-90). the boat still out of the water. to correct this situation i take all the engine oil from lower unit.
my worry is, i dont know if theres any problem to put now the correct gear oil in contact with residues of engine oil.
Can anyone help me?
Thank you to all
Don S
Re: Volvo Penta(AD41P-A) DP sterndrive lower unit gear oil
Won't hurt a thing. Just let it drain for an hour or so. Tilt the drive up slightly so the drain plug is the lowest part.
rayan
thank you very much Don S.:)
