help w/my 140 parts
bain3277
ok i got a 1976 merc 140 i/o i need to know what flywheel and balancer i can use i know that the newer 2.5 dont work.any help would be appreciated thanxs
bain3277
Re: help w/my 140 parts
i need part no for the flywheel help please:confused:
dan t.
any GM neutral ballance flywheel will work as long as the diameter is correct, all have the same bolt pattern on the crank,just go to your local auto wreckers
bain3277
lets try this again i got a flywheel but now i need a lower timming gear
Ayuh,... Timing gears are replaced as Sets,.... Don't replace either 1, without the other...
bain3277
im in the middle the local guys said u couldent but a timming set?? i guess ill have to get more involved. buy the way thanks for all the help
Don S
You can't buy a timing set. Only the cam gear or the crankshaft gear.
Ziggy posted 2 links you can find the gear at, the cam gear part number is 43-46745 (old number from Mercruiser) the new Merc number drops the 43-.
Ooops,... That's the steel gear/ fiber gear, ain't it,..??
bain,... If this is So,... You'll need the fiber gear...
