dumb newby question about shift cable
maxxman04
i hope this is in the right forum too. my apologies if it's not. i have an '89 bayliner capri that had a 2.3l/cobra setup at one time. all of it was removed and replaced with complete mercruiser 898 series setup (350 motor and outdrive) i was able to get all the pieces from a parts boat, everything. the problem, and maybe it's not a problem, maybe it's just me, and that's what i need to know. i've got the project almost complete, and currently working on the throttle and shift cables. i've followed a couple different manuals to make sure of location and such. every cable works great, nice and smooth, full range of motion, exactly like it should. until i attached the lower unit. now, i cannot get it to shift into reverse. i set everything with it in forward and then in neutral. does the motor need to be running for it to shift right? i hope that's the issue and that i am just brain dead. but i want to make sure. thank you.
Bt Doctur
Re: dumb newby question about shift cable
Should shift with the motor off, you may be off 1 spline if you dropped the lower unit for a pump.
maxxman04
ok. i'll drop the lower and move it a spline. thank you.
Bt Doctur
go to the adults section and download the manual. Describes how.
maxxman04
oh, ok. i'll look for it for sure. thank you again for being helpful.
maxxman04
you kick *** Bt Doctur!! that's exactly what i need!!! thanks
maxxman04
oops, my apologies for the language. got a little over excited.
beachinmoney
I'm waiting on an answer too. I just wanted to pop in and tell you I got a chuckle!! Shift cable problems here too!
