saxman9801
Thread starter- Joined
- Apr 30, 2009
- 23
The boat did something weird on me today, I had been running it this afternoon and it was running great, went out and was testing a 4 blade prop, stopped for a while and put my 3 blade back on, then did some skiing and then floated for a bit again. Decided to run back to the dock so crusied down to the park, slowed down for the no wake zone, I was pulling up to the dock at idle and had to reverse a little bit, was some fairly decent sized wakes coming from directly behind me, the boat stalled as I backed up, I tried to fire it up and it caught for a split second at the higher rpm's and then died and no matter what I did woudl not fire back up. I paddeled the last few feet to the dock, let it sit and checked for fuel and spark. I have plenty of fuel at the carb and no issues there, did not have a spark checker with me but pulled a wire off and could hear some ticks as I was cranking. Let it sit for a bit and no luck would crank but would not start. I got a lift back downriver and hauled it back onto the trailer. When I got it home I threw the ears on and tried to start it, it stared up. It seemd a little rough at first and then smoothed out, I had a little bit of smoke/steam coming from the portside manifold. I killed it and checked for leaks and everything looked good. I fired it back up and no more smoke/steam in the enging compartment. it seemed to smooth out after running for a few, it seems like it could still have just a slight miss though at the lower rpms. Could this have been hydrolock, and if so what do I need to check and change to get me running again? The Boat is a 1995 5.7, alpha one carbed 4bbl with the Thunderbolt V. Motor is new this season carb and fuel system is new as well. Boat has been runnign great all season.
Thanks
Dan
Thanks
Dan
