Re: when should fuel lines be changed?
hello, i'm no pro , but from what i know, the fuel lines, depending where they are, should be changed when they get hard and cracking. if they are flexable they should be good, as for the engine cutting off, are you sure its a fuel problem? it could be anything, carb, spark,fuel pump, vacum lock.
again, it depends where/which lines your refering to, tank to motor, fuel pump to carb etc
