Hi guys,
I have a 1986 125hp Force. My prop is not being drawn up tight with the locknut & washer. It has about 1/16" of movement on the splines. Should it be drawn up tight? The splines stick out past the plastic hub that goes on after the prop about 1/16". I can make a washer to correct this but I am not sure if it is needed. 1/16" seems like too much. I can see about 1/64" or less because I dont think you want to put too much pressure on the plastic hub or it will crack.
Any ideas?
Any ideas?
