Re: Stator rotated. Will this effect timing?
The following was from a post about 1 year ago. The link and sinc will not set to factory specs (timing) with out causing the idle RPMS to be to high. Rebuilt carbs, fuel pump, Plugs, good fuel, primer solinoid, and swift kick on the tire did not help. According to the book pictures the stator was rotated a number of degrees and the wiring harness run incorrectly (but worked). I think mercury had a recall and it was replaced under warrenty in 1994.
I have been running this engine with the timing described below because I cannot find a solution. It runs and cranks fine until you run it hard down river before shutting down to get the trailer. Crank it up to load on the trailer and it will not stay running until I full throtle around for a second like blowing it out.
http://forums.iboats.com/showthread.php?t=307952
I have a 1993 Mercury outboard 40 hp ELPTO 4 cyl 2 cycle. This motor is new to me and was running good the 2 times I have had it out on the water except for some sputtering at around 10 mph. I ordered a factory manual so I could check all adjustments. I first noticed the carb linkage wasn?t allowing full throttle while on the trailer. I did not look while running on the water but the RPM on the water is reaching about 5300 at about 29 mph (gps). That seamed average to me for a Pro 17 bass tracker. The motor was idling in the water about right below 800 RPM ? but will not start without choke for a second hot or cold. Now, here?s my problem. Compression equal at 125 psi. I checked the timing using the starter method and it was set to about 6 ATDC, the book said 2 BTDC - 2 ATDC. At full throttle 32 BTDC using the starter method with spark plugs removed. When I set up the timing per the book, I get a high idle situation of 1000-1100 out of the water on water muffs. The carb butterfly valves are closed with no linkage touching. The book says 600-700 RPM in gear in the water. My question is can anyone tell me from experience the difference in idle RPM out of the water and then in the water. I am wondering if the prior owner or tech set the timing lower to achieve a lower idle. It is about 1 hour to the nearest lake to test and I would rather try to get it right at home. Sorry for the long post but I know how important setup info can be.
