Re: What are the symptoms of a bad coil?
A bad coil can go in and out and cause power surges when you get spark on the dead cylinder. It can just lack power totally because one cylinder is dead from no spark. OR, it can run fine, then when the motor warms up and thermal expansion causes you coil to go out, then lose power.
I would think that the simple way to find out would be to check spark, then switch coils and see if the spark failure followed the coil. If you have intermittent spark because the coil goes in and out, it's harder to diagnose. Lots of times, you can pull the plugs and see which one is dirty/oily to find out which one isn't getting good spark.
Good luck,
JBJ
