Alpha 1 intermittent tilt/trim
skargo
Banned
Out on the water today, I could only bring my drive up. I have had an occasional intermittent problem with the transom switch, but this was the first issue with the controls at the helm.
What should I look for first?
jerryjerry05
Re: Alpha 1 intermittent tilt/trim
Bad electrical connections in the switch(WD40).Then the solenoids for bad connections,J
dgopetactical
I had a simular issue and found a loose wire connection at the pump...I would start with the connections at the pump and work toward the switch.. Im sure don has a electrical diagram that will help you out in your seach of your problem....
Denny
skargo
Banned
Thanks guys, I am going to go out and start trouble shooting shortly.
