Can I use red RTV in place of a gasket on the exhasut riser?
rs2k
I either need to get new gaskets or just use red RTV. I've use this in other places in lieu of gaskets.
jerryjerry05
Re: Can I use red RTV in place of a gasket on the exhasut riser?
Get the gaskets.The riser heats up and gools down and the RTV might work for a bit but the riser core gets HOTTTT and the RTV won't last.J
lmannyr
I agree. The gaskets are made of metal, not sure what type of metal but it works and lasts until you split the exhaust again.
dgopetactical
I used the orange hi temp gasket sealer in a bind once and it worked well, ( i live in an area that most dealers dont stock parts they order them/week or 2 turn-around), but I do not recomend this for a perminent application.
Denny
wca_tim
NO!!
and think about the fact that if that particular joint fails... you're talking aobut a new engine. I can't understand why anyone would play russian roulette with exhaust manifolds and risers - if you lose the enginre is an anchor... For that joint above all others I would follow the instructions to the letter...
