jclafayette
Thread starter- Joined
- May 26, 2009
- 3
Hello, I have a 1995 reinell V-6 merc with an Alpha I Gen II stern drive. The Steering acuator (new style) is very loose at slow speed. It is impossible to motor slow in a straight path. The trim tab is set and holds a straight path at speed.
The steering cable housing threads on to the acuator tube and the cable goes through the tube and attaches beyond the tube. The tube has two flat spots for a wrench, and they are vertical as the book says. Mounting bolts and pins are all tight.
It is the tube that has ALOT of side to side movement. Over 1 inch. Can this free play from side to side be adjusted ? The port side of the acuator housing has internal nut that threads into it. It is a ring with holes as though a spaner type wrench turns it and a screw on the top locks it into place. A new complete unit is only a couple hundred $ but will the new one be the same?
Really appreciate any input. Thanks
