v1_0
Thread starter- Joined
- Aug 27, 2007
- 575
So I've found a few soft spots in the deck. Looks like they formed where there were things screwed in - chairs - etc. I'm guessing the carpet held the water and helped it keep things moist.
The boat probably came with these, but I didn't think much of them last year. But I've been reading the Iboats forums over the winter, so now I know what they are.
I'm pretty sure I can repair the other couple of soft spots - they are accessable and I can cut away the wood (45degree angle on the cut) then replace with plywood/epoxy/CSM.
Now the one area that has me puzzled is very near the front, under what seems to be a moulded fiberglass "cap" sort of thing. (Picture attached: the three holes are my exploritory holes, from there forward as far as I can reach it feels like the wood is crumbling). I'm figuring that the deck under that cap is soft. I've figured out a few methods of dealing with this, and was wondering which would be best or if there is any other type of solution.
I should note that there was a set of carpet covered plywood sections making sortof a step up to the section.
Now here are the methods that I've thought of:
1. Ignore this, and keep the heavy people in the back. I'm not liking this option, but it is easier in the short run..
2. Get some 1/4" ply, expoxy & glass it on both sides then shove it under the moulded section. There seems to be some room, at least at the back (aft?) part of it. This would go ontop of the weak deck and out to the sides where the deck is strong.
3. Cut as much as I can get to, replace it, then perform solution #2 to cover the stuff that I can't reach.
4. Cut the moulded section, leaving 2-3 inches from the top of the 'well'. This should give me access to the deck - replace the weak sections, then epoxy & glass the "well" back together. If needed, reinforce the well with some 1/4" plywood/epoxy/fiberglass.
Any thoughts?
Thanks,
-V
Any thoughts?
Thanks,
-V
