Re: 1987 Bayliner Capri Inboard Engine Trouble
I replaced the fuel pump. First time it started I had it idling and moved the throttle slightly forward. after about 30 seconds it made a knocking noise like it was binding and died. Started it again and same thing. Started again and gave it more gas. Seemed to run better for about 5 minutes. I had it running in the driveway. I couldn't really tell if it was running good. I'm afraid to put it in the water again and get stranded (for a third time!).
My guess is the carb. has never been cleaned. Is it worth it to add cleaner to the gas and run it for a while? Is there an "easy" way to clean the carb. for someone that is not good with engines? I replaced the fuel pump -- do you think I can clean the carb. without breaking it?
I have the same engine and had similar troubles at the beginning of the season. Here are some things to check
All fuel filters
- check screen on pick up tube - $0
- check / replace fuel water separator - $15
- check / replace inline fuel filter going into carb. - $2
* Please note on older models, the fuel lines can be fragile. I broke mine and had to replace it changing the filter it was semi-salty at 60 dollars shipped.
I checked these things and found that my problem the whole time was the pesky screen on the fuel pickup tube feeding gas to the rubber fuel line coming out of the gas tank. Darn thing, glad its fixed. Good luck checking yours.
