The 350 block is new,the water cooling system (fresh water) is that of gm305 1978 (long manifolds with the elbows at the back,Tstat housing with the 8 hoses).Even at idle the engine overheats.The incoming water seems enough good.No air bubles get to the system.Both sides of v-block are the same hot.New temperature sender,thermostat housing,thermostat.Relatively new and checked manifolds and elbows.All hoses checked.I have the impression that the water resulting to the elbows is not enough.So the only thing i have not replaced is the (about 5 year old)water circulator and that because it looks in good shape,i 've inspected internally and looks good and it's saft hasn't side to side play.Is there any test available for the circulator?Do they are faulty only when they leak?
