Leardriver
Thread starter- Joined
- Oct 7, 2008
- 382
Hello!
I'm working on a 2004 Glastron GX185 with a Volvo 4.3 and Volvo SX drive. A little bit of water got in through a hole in the u-joint bellows, and I'm replacing the Gimbal bearing and bellows. The u-joints themselves are tight, still move smoothly and like new, since the boat has only 90 hours on it, and had only a trace of rust-colored water on them that wiped off easily. I'm not opposed to changing out the u-joints, but these have the C clips on the outside of the caps and I can't find a replacement joint, only a whole new shaft for several hundred bucks.
Are these u-joints a part that can be run for a while and keep an eye and ear out for, and maybe pull the drive off in 20-30 hours and inspect? Volvo has made it tough to replace these joints, unless someone has a part number for an aftermarket version.
Thanks for your help!
