Phazer230
Thread starter- Joined
- May 28, 2009
- 108
Hi I am replacing a floor in a 23' cuddy cabin. I hope I did not over do it but I already have more than $500 in the floor, I purchased 3/4 marine plywood. 4-sheets $314.00 , carpet $225.00 and the carpet glue. I have the old floor almost all ripped out, it was nasty! My question is how should the floor be properly laid down from here? Should the wood require any other treatment? What should I use to fasten the wood down? Stainless screws or nails? The old floor had some kind of fiberglass coating over it, does this need to be done? or is this just because exterior plywood was used??? If I need to fiberglass the floor exactely what should be used and where can I get it? remember I am using carpet so it will be glued down after the wood is installed. Any advise would be greatly appriciated. Thanks
