Retrofitting a lawn bagger
i386
I have a Troy-Bilt lawn tractor. Someone gave me a bagger that was made for a Murray tractor. I think I've found a way to mount the bagger on the back of my tractor. The part that mates with the exit chute on the deck does not quite match mine. Anyone ever tried something like this? The part is made of plastic. Only ideas I have so far is to trim it as required and use duct tape or trim it and use CSM and resin to build a new part. I don't think the resin will stick to my metal deck (which is a good thing).
dolluper
Re: Retrofitting a lawn bagger
Red Green would be mad ifin you didn't go with the duct tape you might even lose your membership at Possum Lodge
i386
Well I got it working. Just took some trimming of the plastic to make it fit then just drilled some holes and bolted it on. It works fine. I've got less than $4 in it.:)
