Wire diagram for trim pump solenoid?
cheapirish
Folks -
I replaced my down trim pump solenoid today on my Sea Ray 240 Sundancer (year 2000 with 5.0L Bravo III engine) Unfortunately, I did not heed the first instruction in the manual to make a diagram of where the wires all connect! (I even had a phone camera with me that I should have used) The way I've got it hooked up now the pump runs continuously.
Does anyone have a photo or is there a site that shows the diagram of what should be connected to what post? My manual is not detailed enough to give me the detail I need.
Thanks in advance.
patrick
Bt Doctur
Re: Wire diagram for trim pump solenoid?
page5A-10
http://www.boatfix.com/merc/Servmanl/6/6A5R3.PDF
Basically the main power lead goes to 1 lug of both solenoids using a buss bar,the other lug gets a green motor lead (down) and a blue motor lead (up)
small lugs of the solenoids get connected to the trim wires and the solenoids other small lug goes to a ground.
