1984 VRO 90 HP Johnson
gmja4iu
I would like to know what is the purpose of the crank case air. Is that to operate the VRO pump? Does gas get into that? I am thinking of putting an electric fuel pump instead of using the VRO. Can I block off that crank case air nipple? Thanks.
Re: 1984 VRO 90 HP Johnson
electric has not place on an outboard. major fire hazard. either replace with the new OSM pump, or the new premix pump. but do not use electric.
gmja4iu
Where do I get a premix pump. Is there one on the net? I searched and searched.
kenmyfam
If you are going to a premix pump then you should get one from a 1982 (ish) same or greater HP motor.
gmja4iu
Thanks...any idea where I might find one on the internet? Really appreciate this.
seahorse5
Look up a 1983 model of your motor and order the parts needed for a fuel pump and related hoses and fittings.
gmja4iu
It is frustrating to not able to find that premix fuel pump for my 1984 90 HP johnson. I looked everywhere for a 1983 fuel pump.
gmja4iu
gmja4iu
Also they only come in up to 55 HP motor that says non VRO.
direct replacement
Vro Replacement Fuel Pump Kit "no Oil"
(for Using Oil/gas Pre-mix In Fuel Tank)
#5007422 it is in the $300 range.
pump that will work
Part Number: 0385784
Description: FUEL PUMP AY
Pack Qty: 1
Dimensions: 3.50 x 3.50 x 2.25 (in)
Weight: 0.44 lbs
Equivalent Parts: 0395712,0398385,0433390,0438559
you can order here > http://shop2.evinrude.com/ext/index.aspx?s1=bf6ad09c53cead335fcfd8a6471c0f7f
gmja4iu
That's a big help. Thank you very much.
gmja4iu
Hello! I want to thank you all for you help. I happened to found that pre mix pump from an 83 90 HP from Indianapolis and put it on. Tested my boat and sweet thang it is ! Smooth and humming on the water. The VRO pump was bad. Only paid 25.00 for a reconditioned pump. Thank you so much for your help here.
kenmyfam
Now make certain that you remember to premix. Sign on the gas filler may help.
