406 small block install
ironeel
Im thinking of installing a 406 small block in my scarab. Anyone out there familiar with this motor and if it makes a good marine application? :confused:Any info would be helpful.
Thanks
Bt Doctur
Re: 406 small block install
Never heard of a 406
might be helpful to supply some more info, mfg.
Mkos1980
400 SBC bored 30 over = 406
Its a good engine, just build it like any other marine build and you should be fine.
skargo
Banned
I have a Pontiac 406 for my 1967 Lemans, it's a punched out 400 (.30 over)
Ayuh,... But a Pontiac motor Ain't goin' in a Boat...
The 400 Chevy wll work Just Fine....
skargo
Banned
Never said it was, just relating my 406 to the subject matter at hand.
I do know of 2 pontac powered boats BTW ;)
Mkos1980
If you can find Dennis Moores SBC Marine Performance book, he writes very highly of the 400 motor and the steps it take to build one for a marine enviroment.
Ayuh,... The 400 was a Truck motor.... The Problems arose when it was adapted to Hot Rodding...
Bt Doctur
What ever happened to those 327`s with 375Hp
Mkos1980
There out there but you need to turn some serious RPM's to get there. Sorta like the 302 Chevy. I think some of those were turning 7500+ RPM's to achieve those numbers.
bigblocksarefun
I would NOT put a 400 (406) into a marine application. Those engines had a lot of problems (and is why GM stopped making them) and I don't believe it would hold up very well in marine duty. The biggest issue is they had weak main bearing webbing and with 2-bolt mains had a tendancy to come apart when pushed hard for extended periods.
The fact you simply never seen an OEM use it in a boat should tell you something... As in GM never offered it for marine use. I don't know if you can even find marine gaskets (head) for it.
In addition to the above, 400 SBC's are a very thinwall casting (if you are using an old production casting). They don't hold up to overheats well at all. Now a 383 stroker (350 block with 400 crank) makes for a good torquey engine, big block power in a small block package.
MikDee
Banned
On a side note here, I had a 72' Chevy Caprice 2dr Sport Coupe one time with a 402/396 4bbl it was sweet. I happened to find out that if you ordered the V8 eng with a 2bbl, you got a 400 small block :rolleyes: and if you ordered the V8 4bbl version you got the big block, I was pretty happy :D
wca_tim
I've had a couple of 400 small blocks, one that was significantly modified with no real problems...
I love the 383 I had built for my current boat.
I think that either would be great as would one of the longer stroke 4 inch bore set-ups like a 408 (0.25 more stroke than 383.. as in 4" stroke s,mall block...) serious amounts of both torque and horsepower in the right set-ups.
skargo
Banned
hehehe, I had a 72' Caprice myself, but with the 400. That car was a great highway cruiser! I bought mine used though, I was only 5 in '72.
bigblocksarefun
My uncle came into possession of a 70 El Camino that someone had dropped a healthy 400 SBC into (probably pushing about 360 hp or so). Fast car, but scary to try and stop with the original manual drum brakes!:eek:
I've got a 406 in my dirt late model. 4.155 bore in a 184A block. 3.750 stroke. 18 degree bowtie heads. puts out 718 hp and 600 lbs of torque. great engine. however in my boat I have a 120 mercruiser, runs so quiet I can hardly tell its running. :)
Don S
Wait till some of you "Car Guys" find out that a boat engine operates completely different from a car (aka hot rod, street rod, etc.)
What works great in a 70 El Camino (as an example) may be pure junk in a boat within a few trips.
ironeel
Thanks for the input guys, the engine is a 1972 chevy 400 that's bored .030 over. The block is a 2 bolt main high nickel block. My engine builder is putting speed pro pistons (10.1 compression), scat H-beam rods and a forged crank. He said marine gaskets wouldn't be a problem as well as fitting vortec heads to the block. We are going to run a mid range comp marine cam and I was told this engine should have similar characteristics to a 383 but more torque at lower RPM. The motor is going into a 22 scarab.
I was looking for a motor that could get the boat out of the hole and cruise 50 mph all day.
This is what was recommended to me??
Maybe I should have done a 383?
Mkos1980
My 350 will cruise all day at 50MPH.
