2006 Johnson 115 V4 Crossflow
Had a mechanic come out to the house today for my bad idle issue. Compression tested good 125 across all 4 cylinders. He checked spark and it was good as well. He was convinced it is a fuel delivery issue. We get good suction from the carb throats when trying to check them out. I tried spraying fuel into the carb throats but no change. also swapped carbs, no change. We pulled one of the intakes off and found a bad gasket, put back together but still had the issue with the cylinder. I pull the #3 or #4 plug and no change in idle. I am stumped
This boat runs great at WOT.
