FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
i have a 87 sea ray with the 3.0 and when i put it in gear fwrd or bckward it slams really hard. is the idle to high it is a little over 500 it comes out of gear fine
Its hard to say what you consider "hard". Some drives always seem to clunk into gear. If you have a stainless steel prop, it will be even harder.
Is this your first boat?
What make is your drive?
On a 3.0L, you would be lucky if it stayed running at that rpm when in gear. Might want to get a shop tach and verify the actual engine rpm. They do not SLAM into gear at 600, let alone 500.
fellow boater had similar problem...check kill switch at base of shift cable on top of engine (small red and black micro switch) it shuts down engine momentarily when shifting his was stuck closed good luck Tim
