HUB spun agian?
bredd1
2 months ago i had to take my prop to the shop to get it re-hubbed. now only 4 or 5 trips to the lake later my hub has spun out again. (atleast im about 95% sure it has) What could be causing this to keep happenig? What could i do to prevent this? New prob? Any help would be greatly appreciated as i can't afford to keep getting it re-hubbed. Thanks.
kenmyfam
Re: HUB spun agian?
May not have been re-hubbed properly. Check it out again by marking it and running it. If it is spun again then take it back and tell them your issue. Hopefully they will do the job again and properly. Other alternate is to get a new or replacement prop.
What price to do the hub job ???
Re: HUB spun agian?
Ayuh,... Switch to a prop with a replaceable Hub...
bredd1
Re: HUB spun agian?
it costs $60 every time to get it re-hubbed. And i have to drive about an hour and a half to get it fixed. So getting a new prob with a replacable hub would probably be the best idea?
kenmyfam
Re: HUB spun agian?
Get a new prop and get it over with. Good Luck.
Barnacle_Bill
Re: HUB spun agian?
Yeah, the newer hubs are great. If you spin one you just take it out, throw it away, and slide a new one in.
bredd1
Re: HUB spun agian?
thanks for the help. ill definately be getting a new prop
