Sears 3.6hp
RZ6LYV
I have a SEARS 3.6HP and I need to find out what the oil ratio should be. I have heard anywhere from 16:1 to 32:1.
The model # is 217-58588-0.
Also I would like to know the year of motor.
pizzamonkey
Re: Sears 3.6hp
I have a sears 3.6 also, but when i get it running it seems to run for 10 to 15 mins heats up and stops. Wont start again till it cools ,what can cause this?
RZ6LYV
Re: Sears 3.6hp
On this motor the water pump to cool engine only turns when in gear, so I suspect that it is shutting down if you are in neutral.
