1960glastronfireflite
Thread starter- Joined
- Apr 29, 2009
- 11
so i have been working on a 1960 glastron fireflite so far i have split the hull removed the wood floor the lower supports the transom,and the dash. replaced it all with new stronger wood. now i have put the top hull back on and glassed it together in only a few spots since i will have to re seal it when the outer trim is installed. now i need to know a few basic things. what fabric should i redo the seats with? will carpet rot the floor (that is covered 3 times in glass)?
what tyep of carpet is good. and paint what should i use to paint the outer boat i used a self etching primer so far. and last is a boat like this capable of installing a tow bar the manufacturer clams it is but is a 35 hp motor strong enough to do this?
