followme21
Thread starter- Joined
- May 19, 2008
- 65
I am thinkning of putting a pair on my 1984 350 Centruy/Mercruiser...(I like some noise) my question is what type of pipe should I run? I have read where people will use exhaust tube, (which I assume is rubber or something) but I want to make a set that I can control manualy to either run the thur-hull-exhaust or down to the regular exhaust..I see Corsa make electronic control but very expensive.. I would guess regular 3" exhaust designed for automotive purpose would rust rather quickly.. maybe power coat them? would help. Or can a guy get stainless or galvanized 3" pipe.
Also when I run my boat with the muff's on land only a little bit of water actually comes out the prop.. most comes out of two little holes up underneight the lower unit. Is that would I would be replacing if I actually went through with this deal...
Thanks
look forward to hearing replies..
Thanks
