I took the boat out on the first run of the year, other than a few mishaps and fine tweaking of the engine, it ran great. When i was fixing an issue with the fuel hose, i noticed a water leak in the front of the engine right in the area of the raw water pump. I thought what the... Went online and say the ipl on the pump and im thinking the sealing ring went out.
How much work am i looking at taking the pump off and checking/replacing the seal?
When the water dripped into the bilge it was warm, assumed it dribbled down the block, it wasnt antifreeze either.
From looking at the IPL its a pretty simple pump with no bearings that i can see.?
Other than the mishap of the throttle linkage coming off the carb going about 30mph to idle realfast, the boat ran great untill it sucked what it could out of the water seperator and ran out of fuel in the carb. Didnt over heat ran between 180 - 190.
First started Pumped water into the exhanger real fast (didnt have the cap on all the way)
Thanks for the help, looks like VP store sells the gasket for 6 bucks but $7.00 oops ground shipping OUCH...
Thanks
Jason
Thanks
Jason
