1989 4.3 W/OMC drive "thumb"
I have a 1989 Oliver with a 4.3 Merc and OMC drive, I sometimes get a thumb from the drive, like I hit something in the water, it doesn't happen all the time and a different speeds, no griding or nothing just a thump...HELP!
Gary H NC
Re: 1989 4.3 W/OMC drive "thumb"
I'm confused! Is it a Mercruiser or OMC?
danond
Unless someone did a very strange swap, you have a GM 4.3 engine with OMC controls, wiring and other customizations, and an OMC Cobra drive (Made by OMC).
When was the last time your lower/transom shift cable was replaced or adjusted? It sounds like it may be jumping out of gear. If it hasn't been adjusted in the last 2 years, it needs it. If it continues to jump out of gear you will trash your upper drive. A new cable is only $75.
You need to pull the drive and use an OEM service manual to do it properly.
if it jumps out of gear does it pop back in? the thump that I feel (no grind or noise) is just that a thump, like I hit something in the water...thanks
danond
I have no idea, I'm assuming it would, but I would suggest you check your transom shift cable. Aside from lack of gear lube, it's why Cobra outdrives fail.
You better check your lower shift cable but I am afraid it may be too late for your lower gears. That thump is the dog clutch disengaging and the engaging again. Don't drive the boat anymore until you check out your cable. My very first OMC Cobra did the same thing when I first bought it. Dog clutch was toast.
Did yours do it all the time? mine can go a whole day and not do it
Mine did it often. You may be ok then. Definitely need to look at the cable to see if it is still ok and definitely check its adjustment.
Gary H NC
Do NOT attempt to adjust the cable without the manual...I can't stress that enough.
Many gear sets have been destroyed by people adjusting it without the book.
The price of the manual and cable is WAY less than the gears being replaced.
A couple hundred verses a couple thousand....the choice is clear..;)
