Showtime22
Thread starter- Joined
- Jun 1, 2009
- 133
I am having issues with my new electronic ignition.
I have a 1981 Mercruiser 260. (Chevy 350)
I recently installed a Pertronix Ignitor-1 module and the recommended flamethrower coil.
With the Pertronix ignition the boat only seems to have 3/4 power. Not enough to plane out. The weird thing is that if I let off and let the wave rear end the boat, then hit the throttle, the boat will rev much higher and plane....
I ran a full 12 volt fused wire from the key switch, and timed the engine after the install to 8 Degrees BTDC. I also checked the wires for the right firing order and all seems in order. The boat ran 100% with points but after a hard start due to dirty contacts I decided to change to Pertronix.
I have done some deep reading and have heard about the possiblity of the Pertronix Phazing and the module needing to be moved from the magnet ring....
Could this be my problem or what else can I check?
Thanks,
Thanks,
