JGra
Thread starter- Joined
- Apr 24, 2009
- 222
I have an old Merc 200 that I am getting running after sitting for about 15 years. I have made a lot of progress with it so far. I rebuilt the carb and fuel pump. I replaced all the old rotted wire and Have it running really well. The water pump seems to be pumping but I have a new impeller and gasket kit on the way. From what I have read people seem to push the water pump replacement. My question is on the foot. Just above where the lower and upper case come together there is a small tiny 1/8 inch hole that looks like is supposed to be there. There is fresh lower unit oil leaking out of this hole. I just changed the fluid in the foot and it looks fresh. I have seen posts on this and they say unburned oil can come out of this hole but this is fresh lower unit oil. I was also reading where it could be the shift rod seals. The shift rod looks like it runs right next to this hole. I will have the lower half off to do the water pump and am wondering how much of a job it is to do the shift rod seals. Any help would be help full. Thanks
