spike212993
- Joined
- Jun 1, 2009
- 6
Serial Number: OC265997......I have been having trouble with my motor stalling when I open the throttle past approximately 1/2. It will run for about 30 seconds and then shut right down! We have cleaned all 3 carbs. I have sprayed water on plug wires and coils and saw no arcing (but I was only in shade, not night time). I pulled the plug wires off while idling, and although there is spark to all three, there was little change in the way the motor ran when I removed the bottom plug wire. I have ordered fuel pump diaphragm kit as well as coils. By the way, i replaced the spark plugs, and all three looked the same when I did. New gas with stabilizer as well as seafoam first 6 gallons, and gas with stabilizer thereafter. Any thoughts or suggestions would be appreciated, and thanks in advance. Jamie.
