still trying
tired evinrude
ok guys cleaned carbs rebuilt fuel pump new fuel line checked spark and changed coils still cant get it to take wot without bogging down 1982 60hp 2cyl.
jtexas
Re: still trying
Are the throttle plates parallel, closed at idle and horizontal (but not beyond) at WOT?
Does the timer base move smoothly to its stop without sticking when you advance the throttle?
Does the timer base start its motion before the throttles start to open?
Do you have spark on both cylinders across a 7/16" gap on an inline tester clipped to the engine block?
Have you inspected the fuel tank for water and/or debris?
Is the fuel fresh?
What is the compression on this motor?
krogie
Re: still trying
does your motor bog down all the way back to idle? if not i would say it was a fuel problem or a link n synk. if yes it could be a fire problem like a coil or powerpack , i have had similar problems in both situations.
tired evinrude
Re: still trying
recleaned carbs again have new fuel tank. could it be the rectifier. and what is a link@sync. also how do you hook up a tach.
krogie
Re: still trying
A link and sync is when you syncronize you carbs to open up with your spark advance so that you are not calling for fuel and the motor is not ready to advance to that point.as for the rectifier it converts the a/c current to d/c , i do not think this is your problem, have you checked your compression yet?
jtexas
Re: still trying
We can throw out random guesses till the cows come home, but until somebody goes out there and checks on these things, we're just guessing.
1. Are the throttle plates parallel, closed at idle and horizontal (but not beyond) at WOT?
2. Does the timer base move smoothly to its stop without sticking when you advance the throttle?
3. Does the timer base start its motion before the throttles start to open?
4. Do you have spark on both cylinders across a 7/16" gap on an inline tester clipped to the engine block?
5. Have you inspected the fuel tank for water and/or debris?
6. Is the fuel fresh?
7. What is the compression on this motor?
tired evinrude
Re: still trying
ok guys went to harbor picked up a couple nice tools. 150 psi on both cyl. had spak on the top cyl. nothing on the bottom should be the coil correct.
crxess
Re: still trying
Swap coil positions. it it follows the coil is bad. If it stays the same probably power pack.
tired evinrude
Re: still trying
had a bad new coil find out tomorrow runs fine on the ears. harbor frieght has a nice spark check and a good compression cker.thanks
krogie
Re: still trying
good job sounds like the coil gave up the ghost, did you say this was a new coil
tired evinrude
Re: still trying
ok finnaly got out sat. ran fine went back out 3days later and the same thing started again back to scratch.
krogie
Re: still trying
swap the coils around again and see if you burnred another coil , you may still have a powerpack issue.
tired evinrude
Re: still trying
can u have good spark and still have a bad power pack? HOW DO U CHECK A STATOR.
