great site first off.. new guy here. just bought a boat with 91 200 mariner on her. shes got good compression, very clean block, runs good on hose, but ive got questions: first ive got a beep beep beep steady alarm as soon as i start it up which from what ive read its a oil alarm. motor sat for 2 yrs prior to me buying it so i did new water pump, new thermostats, new plugs ect. now at running on hose left bank seems cooler than right bank , right side slightly higher. what gives? wht temp should jacket head metal be? old thermos were packed with sand ,i did run it with out thermos pisser was strong.. but i did replace with new thermos now pisser is weak? what gives there? .... oil buzzer : ive read everything from oil module is bad to poppet valve to float in tank stuck to magnet fell off, oil tanks must be full to reset oil buzzer, i will look and try all these. does anybody know what color wire im looking for for oil module? also it doesnt look like theres a disconnect spot like evinrudes where can i try to unplug this?( iam ordering a manual) now i know theres a mixed feelings on this but should i premix and disconnect oil injection? local mech said i should remove oil pump shaft does this have to be done?one guy just looped it back into tank on here said it worked great. i will pre mix 50:1 just in case while testing this motor . any help would be much appreciated thanks.
