sylv196sport
Thread starter- Joined
- Apr 27, 2009
- 5
I Have a 2000 Slyvan 196 sport with a 4.3 gm serial ol63432either395 cant really tell alpha one drive 0l717822 i have been through this boat new plugs wires dis. cap starter and ign solenoid, also replaced water pump and had to clean the carb seems to run great on the muffs but in the water my hole shot stinks and my top end is poor to say the least, also when i cleaned the carb i set it back to factory like the sealock manual states, also the carb sweats pretty bad on a side note how can you check if your temp sending unit is bad or if its the guage ive allready changed the tstat. thanks for and info or suggestions you all can provide.
