advance timing goes to zero
doboy13golf
I have a 93 ski supreme with a mercruiser 350 mag. converted to electric timing (a delco hei from marine power) initial timing is dead on 8* but advance timing goes to 0* under throttle. put on water and power is way down and it will not get beyond 3000 rpms. I am at a lost? Help.
ps i can hear the advance shut off when i plug the advance cut off in to set initial timing.
Also I had to run another lead to coil from key switch to get a full 12v to the coil.
flargin
Re: advance timing goes to zero
I would say if you find out why you are having problems with the 12v you will find the problem. I have a feeling you may be under-powering the HEI system and it is shutting down.
What do you mean by this? Are you verifying this with a timing light?
doboy13golf
i am getting 12v to coil. ran new line cause the other ran thru a resistor that took it down to 8v for the old points system. the 8v line would not even get a spark on the coil
could it b my tach? works on the dash display. does it comunicate with the coil?
Definitely take your tach off for now. It hooks up to the negative side of the coil. You should see what the directions for the distributor says about tach hook ups to see if they have a seperate tach output.
You need to verify everything with a timing light. Don't do anything by "ear". Once you set base timing, run the engine and verify advance with the timing light at Idle ROM and up. You should be getting at least 25 degrees total advance from idle setting.
doboy13golf
yes all is verified by timing light. advance is going back towards 0* during acceleration. Im lost
disconnected tach no change
OK..next question...is this a standard rotation engine? What is the model number of the distributor?
you have a left hand or right hand rotation engine and what distributor dod you buy for? I can't find that model number by googling it.
doboy13golf
481084 delco HEI kit on mercruiser 5.7 (OD624566) it had points
JustJason
i looked it up and found that it was an est system.
start the engine, let it warm up.
join the 2 white wires on the ignition module together.
disconnect the shift interupt switch and temporarily join the engine harness wires together.
Point, shoot and twist the distro housing until you set your base timing. After you got it shut off the engine. Torque down the distro housing bolt, disconnect the white module wires, hook up your shift interupt switch again.
Should work now, if it doesn't then you probably have a bad ignition module.
Next question. Which way does you engine rotate? I know you have an inboard and it may have a non standard rotation.
JustJason
Perform the procedure I described then report back. Bet it works :)
