Hello all. I have used the search function and read till my eyes hurt, but I did not see quite what I was looking for.
I have a 1965 9.5 HP Johnson that is a model #MQ-11C. The motor did sit for a few years before I got it. Anyway, I put it on the back of the boat, and started it in a barrel of water. It did start, not willingly, but it did start. Did not idle real well, but I figured I could re-clean and adjust the carb later - I wanted to try it on the water first. On the lake the first several pulls felt normal. Then the pulls got harder and did not sound right. One more pull and it's locked up.
Back home - pull the plugs and the bottom cylinder is full of water. I pulled several time to clear the water and sprayed some oil in there. I borrowed a compression gauge and I am getting a reading of 100 on the bottom and only 75 on the top. Repeated the test 3 times to be sure and get the same readings.
I don't have a huge budget for the boat (or I would have a newer motor anyway), so I don't want to start randomly replacing parts. Does it sound like I should start with the head gasket? And could someone be so kind as to let me know what the torque spec and sequence is.
