Lee Taylor
Thread starter- Joined
- Jun 4, 2009
- 10
As the topic states, Johnson 115 tilt/trim problem. I have no issue with the unit lifting the motor UP, it just doesn't want to go back down. Have searched other threads with no joy at this point in time (still looking), so I started my own thread.
The motor runs whether you task it UP or DOWN. I have filled the res. with plenty of fluid. Have attempted a system bleed, but don't know if I've been doing it correctly; help here with the correct procedure would be greatly appreciated. Anyway, had to manually lower the motor to get it to come down. Could I possibly have a problem with the piston? Or is my problem strictly lying by way of bleeding the unit? Took the boat out last weekend and everything still worked. Only thing noted was that it got the the point in cruise (or sitting for that matter) that i have to slightly raise the motor in trim to get it to go back down (thereby thinking bleed/low fluid problem)...and now it won't go down at all afer simply sitting on the trailer at the house. I'm losing valuble fishing time having the boat on the trailer and out of the water. Any and all help will be greatly appreciated!! If I haven't been elaborate enough in explaining something, please ask questions...I will answer to the best of my ability!! THANKS!!
