power trim not workin up
saturnjim
I have a 70 hsp 1994 Johnson outboard and cannot find the power trim up solonid. Motor will only trim down can some one help me thanks
jonesg
Re: power trim not workin up
I believe it uses one solenoid and 2 relays, you can try swapping relays around. Does the trim pump run in UP mode?
could just be an air pocket.
www.outboardbooks.com
the factory manual has 40+pages on the tilt trim system.
