Johnson issues
Re: 95' 115 Johnson Idle issues
new filter, that is an annual change, clean and rebuild carbs, no adjustments on those carbs. oil is residue in exhaust housing, normal for an engine that has sat a while. it is also due for and water pump service.
kenmyfam
Thanks for the reply. I pulled the carbs expecting to see some serious gunk and so far the first is pretty clean and the 2nd has a little varnish on it. Perhaps something is clogged in the jets? I also ordered another filter. When i get the kits and filter in we'll put her back together and see what happens. Hoping this will correct the issue.
Thanks again!
Certainly will not do any harm.
kenmyfam
If the oil smells of gas it's unburnt 2 stroke. If it smells like rotten eggs it's lower unit oil.
Good luck.
Steelhead2634
No rotten egg smell present. Thanks for the help!
Steelhead2634
Well i put my tester on the battery, which is brand new from NAPA as of Friday, and it measured 73%. Hooked it up to my portable power generator and it fired right up. Tested it and it said it was 100%. Perhaps i need a full charged battery to start this motor?
Good thing is that it is running much better at idle. Idle seems to be around 1000rpm's, is that normal? Still has a very slight cough but it doesn't stall it out.
All the help is much appreciated.
