Re: No spark on #1 and #4 after rebuild
You check for spark to test the ignition with all of the plugs out so that the engine can turn at a full 300 RPM. Your test gap should be 7/16 and produce a snappy blue spark. Be sure that your test device is fully grounded.
If you do not get spark on one ignition coil, swap it with another to see if the problem follows the coil.
The ignition coils need to be solidly grounded, so be sure to clean the mounting surface as well as the grounding strap. The spark plug wires have to be solid core, not automotive.
