Re: Speed and proposing problem
Capt. Chris;
Why is it that the prop is the focus of small power boat performance issues? The prop should be appropriate for the boat for sure, but it should not be used to address handling issues. It is for propelling.
When you call trim tabs a band aid I find it to be an interesting "handle" for something that significantly improves ride, handling, acceleration, ability to plain, fuel economy, and eliminates porpoising. I would call them a "performance" enhancing device.
For the record, I do not like hydrofoils in general as a slap it on and go item. No news there I guess.
If you think I am making bold claims about trim tabs, I would be happy to provide third party documentation or you can ask the others on the forums.
There are two key ingredients to boat performance; one is the power plant, and the other is the hull design. Both are equally important! Trim tabs adjust the hull design to compensate for the varying conditions. Don't look at only 1/2 of the problem.
