71 - Adding Tell Tale
phipps
I am wanting to add a tell tale to my 71 Johnson 60hp. I would prefer to not drill into the head. I saw a plug with a slotted head on the top of the head. Can I remove this plug and add a fitting for a tell tale?
Re: 71 - Adding Tell Tale
actually let us know. sure would make things easier for others.
phipps
I will take a pic of the plug tomorrow. I've got to get the motor running before I can worry about the tell tale.
Cranks over great, but I have no spark..... :(
phipps
Here is a picture of the plug in question. It is in the center of the pic towards the bottom half.
R.Johnson
That is a 1/8" pipe plug, or thread. Go to an auto store for that size threaded nipple, and hose,, and you have it.
ezeke
That's a standard 1/8 NPT hole, so you can just use the OEM part or the Sierra one if you want. http://www.iboats.com/Sierra_18_329...2838190--**********.733880435--view_id.174087
  • Outlet elbow (P#321886 0r Sierra # 18-3290)
  • Drill 11/16" hole in lower cowling.
  • Fit bulkhead fitting (P# 0321885) in place from the outside.
  • Run a 3/16" to 5/16" ID hose (P# 321887, 913435, or 327721) connecting the powerhead fitting to the bulkhead fitting.
phipps
Thanks guys!!
Wonder if that was there from the factory or if someone drilled it later.
If I were to put a set of ears on the motor and run water, would it flow through the block or does the motor need to be running? That would be an easy way to confirm if water flows through that area of the block.
ezeke
It shows in the parts catalog as a cylinder plug part #307544, so it should have been there all along.
a70eliminator
That is the first screwdriver slotted NPT plug I've ever seen, is it actually shown as a flat blade plug in the parts sheet your getting the numbers from?
rayodunne
Did you ever complete this? I have the same plug on my motor and it sure seems like an easy way to connect a tell tale.
phipps
No, not yet. Still working on the no spark issue. New points shipped today. Once I have the motor running I'll do the tell tale mod. I'll be sure to come back and let everyone know how it turned out.
rayodunne
Keep an eye on ebay. I got my amp. off there for $50 (NEW) and had to do some modifications to the wiring but it is a way cheaper alternative. I will get the number of mine for you tomorrow!
phipps
Oh wow, that would awesome!!! Thanks!!
rayodunne
I have just completed this tell tale and it worked awesome.
