1964 40hp Johnson Fuel Pump needed.
Stratostreak
In the process of removing the petrified fuel line on my 1964 Johnson 40hp Super Seahorse, we cracked a boss off the platic portion of the fuel pump. I'm looking to buy a new fuel pump for this engine. Can someone tell me where I can find one and what part number I need?
Thanks
F_R
Re: 1964 40hp Johnson Fuel Pump needed.
Thanks
This one should work. The hose comes off the bottom instead of the rear, but who cares.
http://www.iboats.com/Sierra_18_735...6550703--**********.733068191--view_id.174140
tx1961whaler
18-7352 is same pump as 18-7351 except for the diameter of the outlet fitting. The '64 has a small hose/fitting.
Good to know. I thought that the pump bodies looked similar.
reaper2250
Re: 1965 40hp Johnson Fuel Pump needed.
Do you know if this pump will work on a 1965 40 hp? It looks like the same housing.
