cleaning low speed jets
RBNANDM
is it possiable to clean the low speed jets on a 90 hp johnson with out taking off the carbs ? thanks
krogie
Re: cleaning low speed jets
depending on what year it may be posible to do , but a removal would be better. i know it can be a pain to pull the carbs and all the linkage but then you will able to inspect the carb better and do a more complete job. might as well clean the high speed jets and needle valve inspection while your at it.
not properly, as you have to clean the pickups in the bottom of the bowl.
