MID FL CAP
- Joined
- May 20, 2009
- 33
Hello,I removed the thermastat,and broke 3 out of four bolts in the process.I was able to heat 2 of them up and the were removed with a great deal of power.The third one would not move ,so I cut it off and drilled it out with a small drill bit,BUT I went to far and went thru the block,I think.
The question is ,did I really do a lot off damage by goning to far with the drill dit?Is there a water jacket behind that ,or what,I do'nt know for sure? Could I put a little J B weld in it and then the bolt,with some anti-seize on it then the gasket and call it good,or a nother course of action reqired? Hope some small fix-it or major job? At any rate the t-stats were shot,so I was doing something right by inspecting them before heading for blue water!! THANK YOU for your help in advance!!!Ray.
