twin johnson 140 fuel problem
pitbulll
hi guys i haved several problems with my engine in the past and all have been resolved by all of your great advise.thank you so much
this one is for my brother.he has twin johnson 1992 140HP it cranks up fine and idles fine.but at WOT it stalls and the fuel line gets sucked up.he then loosens the clamp at the fuel line and when it suck air back in the line then the fuel line looks normal.if he trys to WOT again then they suck up again.any advise to him what can be causing this problem.thanks in advance
...pitbull
ezeke
Re: twin johnson 140 fuel problem
If the primer bulb collapses, the problem is before the bulb or in the bulb itself.
Check the pickup screen in the fuel tank, the anti-siphon valve at the top of the tank outlet, use only marine full-sized fuel filters and 3/8" ID fuel line.
Allowing air into the fuel or oil lines line will cause the engine to run lean with possible piston damage resulting.
jtcarter
Check your fuel tank vent.
pitbulll
ok guys i will tell him to check this and report back to you all.thanks for the info
