I have a 1963 Johnson 40 HP (RD-25) and I need to remove the flywheel to gain access to the ignition. I have tried for three weeks to get the flywheel off.....soaked in PB Blaster, used a harmonic puller w/hammer and impact driver, I have even talked nice to it. The flywheel is still stuck on there.
I have a donor motor (I need the electric stater motor and fuel pump) from 1961 (RDS-23). Does anyone who if the flywheel is interchangeable? I have noticed the flywheel nut on the '61 donor is smaller, but the top of flywheel tapper looks the same size.
Any advice on how to get the old flywheel, if they are interchangable, or where to get the right flywheel would be helpful.
Thanks!
Thanks!
