Carburator Help Please
nobelstephan
My 70 hp Evinrude motor has three cylinders with three carburetors. The middle piston seems to not be getting gas. It has spark. The motor runs on 2 cylinders and would die when pushing throttle. Sprayed full can of carburetor cleaner with no use. All three cylinders have vacuum over 120#. It has new fuel pump and new spark plugs. Any suggestion what may cause it and how to fix it? Thanks.
iwombat
Re: Carburator Help Please
Spraying carb cleaner down the throat will do nothing except remove lubrication in the crankcase.
You need to remove and rebuild your carb(s) if it truly is a no fuel problem.
crxess
^^^^^^^^^.........only way to correct it. Spray some pre mix it there while cranking to lube the bearings up. then Pull/rebuild the carb.
krogie
considering you have anew fuel pump i would go stright for a re-build. sounds like the needle valve may be stuck and not allowing fuel to enter . you can try taping on the carb to see if that lossens the foat or the needle valve ( worked for me before when i was in a pinch). good luck!!
